[postgis-devel] [PostGIS] #1345: ST_StartPoint, ST_EndPoint regress failure
trac at osgeo.org
Fri Dec 9 05:42:09 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
It might be this change: r6264
I'll try to compile the version before to see if that used to work. Maybe
it was an accidental change and that the old behavior was smart enough to
work with a single line string wrapped in a multi wrapper and peel it out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1345#comment:5>
