[postgis-devel] [PostGIS] #1323: lwgeom_extent_to_gml3 segfaults when passed an LWGEOM with no BBOX cache
trac at osgeo.org
Fri Dec 9 05:52:19 PST 2011
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
Fixed by r8333, which includes comprensive regress testing. The EMPTY case
may be subject to change.
Note that the commit also fixes support for srsDimension option (don't
remember how to specify that option at the SQL level but should be written
in the manual page, the tests I added were at the liblwgeom level).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1323#comment:4>
