[postgis-devel] Rasteraddconstraints does not match raster2pgsql.py information
Jose Carlos Martinez jomarlla at cgf.upv.es
Fri Dec 9 07:12:58 PST 2011
Hi, Im a litte bit confused about the addrasterconstraints function
(r8332 version).
Now after importing a raster with:
raster2pgsql.py -r ASTGTM2_N39E002_dem.tif -t dem1 -k 200x200 -I -M -o
dem1.sql
This functions  is using still addrastercolumn what I think its gonna
change soon. It gives me the following information:
public.dem1.rast srid:-1 pixel_types:{16BSI} out_db:false
regular_blocking:true nodata_values:NULL scale_x:'0.000277777777778'
scale_y:'-0.000277777777778' blocksize_x:'200' blocksize_y:'200'
extent:POLYGON((1.99986111111111 38.9998611111111,1.99986111111111
40.0001388888889,3.00013888888889 40.0001388888889,3.00013888888889
38.9998611111111,1.99986111111111 38.9998611111111))
It does not fill the values in raster_columns (I guess this is because
it was not updated to use addrasterconstraints).
then I used:
select addrasterconstraints ('dem1','rast');
and it filled the values in raster_columns but they dont match the
values got from raster2pgsql.py.
I get raster_columns with:
  r8332-1         | public         | dem1         | rast            |
-1 |         |         |         200 |         200 | t              |
f                |         1 | {16BSI}     | {0}           |
010300000001000000050000002A3B4C5D6EFFFF3FB5814E1BE87843402A3B4C5D6EFFFF3F279E158D04004440B1E4174B7E710840279E158D04004440B1E4174B7E710840B5814E1BE87843402A3B4C5D6EFFFF3FB5814E1BE8784340
The extent does not match with raster2pgsql values and it said the block
is not regular when it is.
Should I use addrasterconstraint specifying all the information in the
arguments?, or im doing wroing?
Cheers,
Jose
