[postgis-devel] [PostGIS] #665: TGeom regress crash on Linux 64 bits
trac at osgeo.org
Fri Dec 9 07:39:53 PST 2011
Reporter: colivier | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: TGeom Tin PolyhedralSurface |
Comment(by strk):
Do you guys mind if I change the unit test suite names ?
I've started already with some of them so to match filename.
It helps when you're focusing on a single file as you can specify the name
as an argument to cu_tester, as in:
./cu_tester surface
Which is much easiear to type than:
./cu_tester "Triangle, Tin and PolyhedralSurface Suite"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/665#comment:2>
