[postgis-devel] [PostGIS] #665: TGeom regress crash on Linux 64 bits
trac at osgeo.org
Fri Dec 9 08:29:38 PST 2011
Reporter: colivier | Owner: coliver
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: TGeom Tin PolyhedralSurface |
Changes (by strk):
* owner: strk => coliver
* priority: medium => blocker
* status: assigned => new
Comment:
With r8337 I've renamed the suite and restricted the disabled code so it's
clearer where the problems occur. I'll re-assign this to coliver as I
guess he's the author of the code so he knows what's the serialized format
supposed to be for surfaces.
Tagging this as a blocker while assuming the memory corrupting code path
is exposed to SQL.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/665#comment:7>
