[postgis-devel] [PostGIS] #1359: Cleanup after box3d_extent removal
PostGIS trac at osgeo.org
Fri Dec 9 09:19:42 PST 2011
  Reporter:  strk     |       Owner:  pramsey
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 r8338 adds the skips to posgis_restore.pl and new_postgis_restore.pl
 I don' think we also need to do something in legacy install/uninstall
 since box3d_extent type would require the C side of things so probably
 won't work with an SQL only approach...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1359#comment:2>
