[postgis-devel] [PostGIS] #1297: [raster] C version of raster2pgsql
trac at osgeo.org
Fri Dec 9 18:00:54 PST 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* priority: high => critical
Comment:
Usage flags for raster2pgsql.
USAGE: raster2pgsql [<options>] <raster>[ <raster>[ ...]]
[[<schema>.]<table>]
OPTIONS:
-s <srid> Set the raster's SRID. Defaults to 0.
-b <band> Index (1-based) of band to extract from raster. For more
than one band index, separate with comma (,). If unspecified,
all bands of raster will be extracted.
-t <tile size> Cut raster into tiles to be inserted one per
table row. <tile size> is expressed as WIDTHxHEIGHT.
-R Register the raster as an out-of-db (filesystem) raster. Provided
raster should have absolute path to the file
(-d|a|c|p) These are mutually exclusive options:
-d Drops the table, then recreates it and populates
it with current raster data.
-a Appends raster into current table, must be
exactly the same table schema.
-c Creates a new table and populates it, this is the
default if you do not specify any options.
-p Prepare mode, only creates the table.
-f <column> Specify the name of the raster column
-F Add a column with the filename of the raster.
-l <overview factor> Create overview of the raster. For more than
one factor, separate with comma(,). Overview table name follows
the pattern o_<overview factor>_<table>. Created overview is
stored in the database and is not affected by -R.
-q Wrap PostgreSQL identifiers in quotes.
-I Create a GIST spatial index on the raster column. The ANALYZE
command will automatically be issued for the created index.
-M Run VACUUM ANALYZE on the table of the raster column. Most
useful when appending raster to existing table with -a.
-C Set the standard set of constraints on the raster
column after the rasters are loaded. Some constraints may fail
if one or more rasters violate the constraint.
-x Disable setting the max extent constraint. Only applied if
-C flag is also used.
-r Set the regular blocking constraint. Only applied if -C flag is
also used.
-T <tablespace> Specify the tablespace for the new table.
Note that indices (including the primary key) will still use
the default tablespace unless the -X flag is also used.
-X <tablespace> Specify the tablespace for the table's new index.
This applies to the primary key and the spatial index if
the -I flag is used.
-N <nodata> Nodata value to use on bands without a nodata value.
-E <endian> Control endianness of generated binary output of
raster. Use 0 for XDR and 1 for NDR (default). Only NDR
is supported at this time.
-V <version> Specify version of output format. Default
is 0. Only 0 is supported at this time.
-e Execute each statement individually, do not use a transaction.
-Y Use COPY statements instead of INSERT statements.
-? Display this help screen.
Flags were selected and named to maintain a middle-ground between those
flags in raster2pgsql.py and the well-established flags of shp2pgsql.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1297#comment:1>
