[postgis-devel] [PostGIS] #1333: Support geocoding of cross streets
trac at osgeo.org
Sun Dec 11 18:03:32 PST 2011
Reporter: arencambre | Owner: robe
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by robe):
Aren,
Which cross streets were you trying to geocode and can you provide the
statement you were using. I don't have all the states loaded in my Db,
but the ones I have tried have worked.
Also did you check the manual? http://www.postgis.org/documentation
/manual-svn/Geocode_Intersection.html
Also Which PostgreSQL version are you running on?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1333#comment:6>
