[postgis-devel] [PostGIS] #1362: Remove lwgeom_gist.c
PostGIS trac at osgeo.org
Mon Dec 12 08:11:30 PST 2011
  Reporter:  pramsey  |       Owner:  strk
      Type:  task     |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Done in r8362. There were no much dependent objects.
 There are still mentions in uninstall_postgis.sql.in.c: is that file
 maintained manually ?
 Should it be a mirror of postgis.sql.in.c ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1362#comment:2>
