[postgis-devel] [PostGIS] #1367: Provide a clear upgrade path to 2.0
trac at osgeo.org
Tue Dec 13 01:00:44 PST 2011
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
By the end of the process above I end up with some tables using geometry
column constraints and some tables using typmod. We may need a step 4. to
perform the cleanup/conversion or embed that part directly into step 3.
(postgis_restore phase). Splitting would help debugging and be probably
safer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1367#comment:2>
