[postgis-devel] [PostGIS] #1365: postgis_upgrade_20_minor.sql is broken
trac at osgeo.org
Tue Dec 13 01:05:44 PST 2011
Reporter: robe | Owner: strk
Type: defect | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Changes (by strk):
* owner: pramsey => strk
* status: new => assigned
Comment:
The structure changed adding:
check (srid > 0 and srid < 999000)
The check would be safer to add after making sure nothing breaks it.
Speaking of which, the new_postgis_upgrade script defines the table using
the new definition and would thus fail loading data with SRID values >=
999000
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1365#comment:1>
