[postgis-devel] [PostGIS] #1320: typmod geometry type not changing in before trigger
PostGIS trac at osgeo.org
Thu Dec 15 15:29:51 PST 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  postgis   |     Version:  trunk
Resolution:  fixed     |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 r8431 fixes this case.
 I've found the culprit for calls to LWGEOM_in w/out 3rd argument:
 lwgeom_inout.c:450:     result = DirectFunctionCall1(LWGEOM_in,
 CStringGetDatum(wkt));
 which is Datum parse_WKT_lwgeom(PG_FUNCTION_ARGS)
 It would be hard to get a similar situation for geography, anyway better
 safe than sorry, so the geography_in support for such calls is in r8432
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1320#comment:7>
