[postgis-devel] [PostGIS] #1381: [raster] two-raster ST_Intersection
trac at osgeo.org
Fri Dec 16 08:46:31 PST 2011
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords: history
Comment(by bnordgren):
THis is the first example of how to use the raster iterator.
https://github.com/bnordgren/postgis/blob/ri-
gen2-svn/raster/rt_pg/rt_pg.c#L9726
That function will do any of intersection, difference, symdifference, or
union between two individual raster objects, returning raster. Similar
functions may be constructed for vector/raster, raster/vector (order
doesn't make a difference for intersection, but will for difference.)
It can handle multiple bands from both rasters (but requires the same
number of bands from each.)
It is currently optimized for "return the value from the first raster
unless NODATA, in which case, return the value from the second raster." It
really seems bizarre to hardcode "FIRST" or "SECOND" in an intersection
operation, as that describes "subset" or ST_Clip...particularly in the
alternatives: geom/raster, raster/geom.
It does handle on the fly reprojection, but that can be disabled if it's
unwanted.
Mostly, it should be instructive to see the code as an example of how to
use the SPATIAL_COLLECTION type to set up an on-demand computation chain
which is then queried for a value at each cell location in the output
raster. It should also demonstrate that once code is written against the
SPATIAL_COLLECTION type, it suddenly doesn't matter whether the input was
an LWGEOM or a rt_raster--and that's for each link in the processing
chain. You can squeeze a lot of reuse out of this because you don't need
special code for each combination.
If I adapt this particular function so it matches the signature on this
ticket, does this sound like a good target for an "initial example of the
framework"? Is that going to be concrete enough for you guys to evaluate?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1381#comment:3>
