[postgis-devel] [PostGIS] #1173: TopologyException from intersection of valid geography
trac at osgeo.org
Fri Dec 16 09:30:17 PST 2011
Reporter: jgilman | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by jgilman):
* status: closed => reopened
* resolution: invalid =>
Comment:
The geography described by those points is not invalid. The documentation
says that st_isvalid only works on geometry (not geography).
http://postgis.refractions.net/docs/ST_IsValid.html As such it won't
correctly validate the geography that I was using to demonstrate this
problem. This is a polygon that wraps around the north pole which isn't
possible as a geometry object in postgis but should be possible as
geography.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1173#comment:8>
