[postgis-devel] [PostGIS] #597: [raster] ST_Clip
PostGIS trac at osgeo.org
Fri Dec 16 11:37:34 PST 2011
 Reporter:  pracine         |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by dustymugs):
  * status:  new => assigned
Comment:
 From the looks of it, Pierre's ST_Clip has the following signatures.
 1. ST_Clip(
         rast raster, band int,
         geom geometry,
         nodata float8 DEFAULT null,
         trimraster boolean DEFAULT false
 2. ST_Clip(
         rast raster,
         geom geometry,
 3. ST_Clip(
         geom geometry,
         trimraster boolean
 4. ST_Clip(
         rast raster,
         geom geometry,
         trimraster boolean
 I'm wondering if the "nodata" parameter could be dropped as I would
 consider ST_Clip a pure extent constraining function with no data
 manipulation.  Also, I'd like to see trimraster default to TRUE as the
 primary purpose of ST_Clip is to cut up the raster to only the area(s) of
 interest.  Will need to ask postgis-devel as there are one or two users of
 ST_Clip.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/597#comment:6>
