[postgis-devel] Fixing floating point precision issues under gcc
Sandro Santilli
strk at keybit.net
Wed Dec 21 07:42:41 PST 2011
On Thu, Dec 15, 2011 at 10:51:20AM +0000, Mark Cave-Ayland wrote:
> Yes, I believe this could be related. The quick test would be to run
> configure and then manually add -fexcess-precision=standard to
> CFLAGS in liblwgeom/Makefile and PG_CPPFLAGS in postgis/Makefile and
> then do a complete make install and test once again.
Mark: if you want to help with the geos side of this:
http://trac.osgeo.org/geos/ticket/504
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
