[postgis-devel] [PostGIS] #301: [raster] Add uninstall_rtpostgis.sql machinery
PostGIS trac at osgeo.org
Wed Dec 21 11:56:15 PST 2011
 Reporter:  mloskot                |       Owner:  robe
     Type:  enhancement            |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by dustymugs):
 Possible use of pg_dump --clean --schema-only to generate
 uninstall_rtpostgis.sql.  A static one would be the default but make
 should be able to generate a dynamic one.  make would need to create a
 database (like regress), populate the database, run the dump, create the
 uninstall script and then drop the database.  Regression test could test
 the static (or dynamic) uninstall script to make sure the uninstall works.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/301#comment:9>
