[postgis-devel] [PostGIS] #1396: No definition of INFINITY on Solaris/GCC
PostGIS trac at osgeo.org
Thu Dec 22 00:05:12 PST 2011
  Reporter:  martin   |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  Solaris infinity
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 That file is the only one using INFINITY.
 In r8499 I changed it to use MAXFLOAT instead.
 Paul: no regression test failed and the functions did look like only
 needing a value ensured to be higher than the others. If you see a problem
 with this feel free to reopen.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1396#comment:1>
