[postgis-devel] [PostGIS] #1153: uninstall script is broken
trac at osgeo.org
Thu Dec 22 01:10:53 PST 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by strk):
Beside, the other order would also be broken as you can't drop one w/out
dropping the other. Which also means you'll _need_ the CASCADE.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1153#comment:6>
