[postgis-devel] pgraster: st_resample error
Tom van Tilburg
tom.van.tilburg at gmail.com
Fri Dec 23 07:58:41 PST 2011
Hi Bborie,
thanks.
I keep an eye on the ticket but it's a bit beyond my abilities to
understand all of it ;-)
My 2 cents however on Evens post:
The errors in the amersfoort (28992) projecten have been known for a
long time, that's not what bothers me at the moment.
From all the small errors in the google-mercator projections (I think
there are 4 around, all slightly different) I have never seen 20 km.
error in the offset. It more feels to me that numbers have been swapped
instead of miscalculated.
The fact that postgis moves it 20 km south while gdal_warp moves it 20
km the opposite direction is also puzzling. What could that indicate?
I'll keep an eye on the gdal list as well. Are you posting there?
Cheers,
Tom
On 23-12-2011 16:38, Bborie Park wrote:
> Tom,
> When you have the chance, can you look at ticket #1402?
> http://trac.osgeo.org/postgis/ticket/1402
> Even from the GDAL project responded with a thorough explanation of
> what's causing the drift. I'm still digesting his explanation and
> will see what can be done to improve the projection handling in
> PostGIS Raster. Currently, we use the value in the "srtext" column of
> spatial_ref_sys, but it looks like we may have better luck using the
> "proj4text" column and have GDAL process it through their mechanisms.
> -bborie
