[postgis-devel] build problems on CENTOS 6.2
Paul Ramsey
pramsey at opengeo.org
Fri Dec 23 10:51:05 PST 2011
No, no ideas. It says you're missing symbols that are certainly there
unless you have an old version of the .so hanging around somehow
getting in the way. Try a completely fresh source tree?
P.
On Fri, Dec 23, 2011 at 7:37 AM, Nathaniel Clay
<clay.nathaniel at gmail.com> wrote:
> Paul
> Completeted make clean, autogen.sh and configure and then rebuild and still
> having the same error.
> Have any ideas?
> Thanks,
> Nathaniel H Clay
> On Thu, Dec 22, 2011 at 8:28 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> If you're operating off of svn checkout, make clean and re-run
>> ./autogen and ./configure before rebuilding.
>> P.
>> On Thu, Dec 22, 2011 at 4:52 PM, Nathaniel Clay
>> > Hi all,
>> > Having trouble building postgis svn on my machine. Here is the output
>> > from
>> > make..
>> > for s in liblwgeom libpgcommon regress postgis loader utils raster
>> > topology;
>> > do \
>> > echo "---- Making all in ${s}"; \
>> > make -C ${s} all || exit 1; \
>> > done;
>> > ---- Making all in liblwgeom
>> > make[1]: Entering directory `/home/nathan/code/postgis/liblwgeom'
>> > /bin/sh ../libtool --tag=CC --mode=link gcc -rpath /usr/local/lib
>> > stringbuffer.lo measures.lo measures3d.lo box2d.lo ptarray.lo
>> > lwgeom_api.lo
>> > lwgeom.lo lwpoint.lo lwline.lo lwpoly.lo lwtriangle.lo lwmpoint.lo
>> > lwmline.lo lwmpoly.lo lwcollection.lo lwcircstring.lo lwcompound.lo
>> > lwcurvepoly.lo lwmcurve.lo lwmsurface.lo lwpsurface.lo lwtin.lo
>> > lwout_wkb.lo
>> > lwin_wkb.lo lwout_wkt.lo lwin_wkt_parse.lo lwin_wkt_lex.lo lwin_wkt.lo
>> > lwutil.lo lwhomogenize.lo lwalgorithm.lo lwsegmentize.lo lwprint.lo
>> > vsprintf.lo g_box.lo g_serialized.lo g_util.lo lwgeodetic.lo lwtree.lo
>> > libtgeom.lo lwout_gml.lo lwout_kml.lo lwout_geojson.lo lwout_svg.lo
>> > lwout_x3d.lo lwgeom_geos.lo lwgeom_geos_clean.lo lwgeom_geos_node.lo
>> > lwgeom_geos_split.lo lwgeom_transform.lo lwspheroid.lo -release 2.0.0SVN
>> > -L/usr/lib64 -lgeos_c -lproj -o liblwgeom.la
>> > libtool: link: rm -fr .libs/liblwgeom-2.0.0SVN.so .libs/liblwgeom.a
>> > .libs/liblwgeom.la .libs/liblwgeom.lai .libs/liblwgeom.so
>> > libtool: link: gcc -shared .libs/stringbuffer.o .libs/measures.o
>> > .libs/measures3d.o .libs/box2d.o .libs/ptarray.o .libs/lwgeom_api.o
>> > .libs/lwgeom.o .libs/lwpoint.o .libs/lwline.o .libs/lwpoly.o
>> > .libs/lwtriangle.o .libs/lwmpoint.o .libs/lwmline.o .libs/lwmpoly.o
>> > .libs/lwcollection.o .libs/lwcircstring.o .libs/lwcompound.o
>> > .libs/lwcurvepoly.o .libs/lwmcurve.o .libs/lwmsurface.o
>> > .libs/lwpsurface.o
>> > .libs/lwtin.o .libs/lwout_wkb.o .libs/lwin_wkb.o .libs/lwout_wkt.o
>> > .libs/lwin_wkt_parse.o .libs/lwin_wkt_lex.o .libs/lwin_wkt.o
>> > .libs/lwutil.o
>> > .libs/lwhomogenize.o .libs/lwalgorithm.o .libs/lwsegmentize.o
>> > .libs/lwprint.o .libs/vsprintf.o .libs/g_box.o .libs/g_serialized.o
>> > .libs/g_util.o .libs/lwgeodetic.o .libs/lwtree.o .libs/libtgeom.o
>> > .libs/lwout_gml.o .libs/lwout_kml.o .libs/lwout_geojson.o
>> > .libs/lwout_svg.o
>> > .libs/lwout_x3d.o .libs/lwgeom_geos.o .libs/lwgeom_geos_clean.o
>> > .libs/lwgeom_geos_node.o .libs/lwgeom_geos_split.o
>> > .libs/lwgeom_transform.o
>> > .libs/lwspheroid.o -L/usr/lib64 -lgeos_c -lproj -Wl,-soname
>> > -Wl,liblwgeom-2.0.0SVN.so -o .libs/liblwgeom-2.0.0SVN.so
>> > libtool: link: (cd ".libs" && rm -f "liblwgeom.so" && ln -s
>> > "liblwgeom-2.0.0SVN.so" "liblwgeom.so")
>> > libtool: link: ar cru .libs/liblwgeom.a stringbuffer.o measures.o
>> > measures3d.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
>> > lwpoly.o lwtriangle.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
>> > lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o
>> > lwpsurface.o lwtin.o lwout_wkb.o lwin_wkb.o lwout_wkt.o lwin_wkt_parse.o
>> > lwin_wkt_lex.o lwin_wkt.o lwutil.o lwhomogenize.o lwalgorithm.o
>> > lwsegmentize.o lwprint.o vsprintf.o g_box.o g_serialized.o g_util.o
>> > lwgeodetic.o lwtree.o libtgeom.o lwout_gml.o lwout_kml.o lwout_geojson.o
>> > lwout_svg.o lwout_x3d.o lwgeom_geos.o lwgeom_geos_clean.o
>> > lwgeom_geos_node.o
>> > lwgeom_geos_split.o lwgeom_transform.o lwspheroid.o
>> > libtool: link: ranlib .libs/liblwgeom.a
>> > libtool: link: ( cd ".libs" && rm -f "liblwgeom.la" && ln -s
>> > "../liblwgeom.la" "liblwgeom.la" )
>> > make[1]: Leaving directory `/home/nathan/code/postgis/liblwgeom'
>> > ---- Making all in libpgcommon
>> > make[1]: Entering directory `/home/nathan/code/postgis/libpgcommon'
>> > make[1]: Nothing to be done for `all'.
>> > make[1]: Leaving directory `/home/nathan/code/postgis/libpgcommon'
>> > ---- Making all in regress
>> > make[1]: Entering directory `/home/nathan/code/postgis/regress'
>> > make[1]: Leaving directory `/home/nathan/code/postgis/regress'
>> > ---- Making all in postgis
>> > make[1]: Entering directory `/home/nathan/code/postgis/postgis'
>> > gcc -E -traditional-cpp -I../libpgcommon postgis.sql.in.c | grep -v '^#'
>> > postgis.sql.in
>> > sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' postgis.sql.in
>> > >postgis.sql
>> > gcc -E -traditional-cpp -I../libpgcommon uninstall_postgis.sql.in.c |
>> > grep
>> > -v '^#' > uninstall_postgis.sql.in
>> > sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' uninstall_postgis.sql.in
>> > cat postgis_drop_before.sql.in.c postgis.sql >
>> > postgis_upgrade_20_minor.sql.in
>> > '/usr/bin/perl' ../utils/postgis_proc_upgrade.pl
>> > postgis_upgrade_20_minor.sql.in 2.0 > postgis_upgrade_20_minor.sql
>> > gcc -E -traditional-cpp -I../libpgcommon legacy.sql.in.c | grep -v '^#'
>> > legacy.sql.in
>> > sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' legacy.sql.in >legacy.sql
>> > gcc -E -traditional-cpp -I../libpgcommon uninstall_legacy.sql.in.c |
>> > grep -v
>> > '^#' > uninstall_legacy.sql.in
>> > sed 's,MODULE_PATHNAME,$libdir/postgis-2.0,g' uninstall_legacy.sql.in
>> > legacy_compatibility_layer.sql.in.c
>> > | grep -v '^#' > legacy_compatibility_layer.sql.in
>> > legacy_compatibility_layer.sql.in >legacy_compatibility_layer.sql
>> > gcc -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
>> > -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
>> > -I/usr/include/et -Wall -Wmissing-prototypes -Wpointer-arith
>> > -Wdeclaration-after-statement -Wendif-labels -Wformat-security
>> > -fno-strict-aliasing -fwrapv -fpic -I/usr/include
>> > -I/usr/include/libxml2
>> > -I../liblwgeom -I../libpgcommon -I. -I. -I/usr/pgsql-9.1/include/server
>> > -I/usr/pgsql-9.1/include/internal -I/usr/include/et -D_GNU_SOURCE
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_debug.o
>> > lwgeom_debug.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o postgis_module.o
>> > postgis_module.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_accum.o
>> > lwgeom_accum.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_spheroid.o
>> > lwgeom_spheroid.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_ogc.o lwgeom_ogc.c
>> > lwgeom_functions_analytic.o
>> > lwgeom_functions_analytic.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_inout.o
>> > lwgeom_inout.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_functions_basic.o
>> > lwgeom_functions_basic.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_btree.o
>> > lwgeom_btree.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_box.o lwgeom_box.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_box3d.o
>> > lwgeom_box3d.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_geos.o
>> > lwgeom_geos.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_geos_prepared.o
>> > lwgeom_geos_prepared.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_geos_clean.o
>> > lwgeom_geos_clean.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_geos_relatematch.o
>> > lwgeom_geos_relatematch.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_export.o
>> > lwgeom_export.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_in_gml.o
>> > lwgeom_in_gml.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_in_kml.o
>> > lwgeom_in_kml.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_in_geojson.o
>> > lwgeom_in_geojson.c
>> > lwgeom_in_geojson.c:19: warning: ‘geojson_lwerror’ defined but not used
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_triggers.o
>> > lwgeom_triggers.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_dump.o
>> > lwgeom_dump.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_functions_lrs.o
>> > lwgeom_functions_lrs.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o long_xact.o long_xact.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_sqlmm.o
>> > lwgeom_sqlmm.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_rtree.o
>> > lwgeom_rtree.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o lwgeom_transform.o
>> > lwgeom_transform.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o gserialized_typmod.o
>> > gserialized_typmod.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o gserialized_gist_2d.o
>> > gserialized_gist_2d.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o gserialized_gist_nd.o
>> > gserialized_gist_nd.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o geography_inout.o
>> > geography_inout.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o geography_btree.o
>> > geography_btree.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o geography_estimate.o
>> > geography_estimate.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o geography_measurement.o
>> > geography_measurement.c
>> > -I/usr/include/libxml2 -I/usr/include -c -o geometry_estimate.o
>> > geometry_estimate.c
>> > -fno-strict-aliasing -fwrapv -fpic -shared -o postgis-2.0.so
>> > lwgeom_debug.o
>> > postgis_module.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o
>> > lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_functions_basic.o
>> > lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o lwgeom_geos.o
>> > lwgeom_geos_prepared.o lwgeom_geos_clean.o lwgeom_geos_relatematch.o
>> > lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geojson.o
>> > lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o long_xact.o
>> > lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o gserialized_typmod.o
>> > gserialized_gist_2d.o gserialized_gist_nd.o geography_inout.o
>> > geography_btree.o geography_estimate.o geography_measurement.o
>> > geometry_estimate.o -L/usr/pgsql-9.1/lib -L/usr/lib64 -Wl,--as-needed
>> > ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a
>> > -L/usr/lib64
>> > -lgeos_c -lproj -lxml2 -lz -lm
>> > make[1]: Leaving directory `/home/nathan/code/postgis/postgis'
>> > ---- Making all in loader
>> > make[1]: Entering directory `/home/nathan/code/postgis/loader'
>> > /bin/sh ../libtool --mode=link gcc -g -O2 -fPIC -DPIC -Wall
>> > -Wmissing-prototypes -DUSE_NLS
>> > -DLOCALEDIR=\"/usr/pgsql-9.1/share/locale\" shpopen.o dbfopen.o
>> > getopt.o
>> > shp2pgsql-core.o shpcommon.o shp2pgsql-cli.o safileio.o
>> > ../liblwgeom/liblwgeom.la -o shp2pgsql -lc
>> > libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>> > -DUSE_NLS
>> > -DLOCALEDIR=\"/usr/pgsql-9.1/share/locale\" shpopen.o dbfopen.o getopt.o
>> > shp2pgsql-core.o shpcommon.o shp2pgsql-cli.o safileio.o -o
>> > .libs/shp2pgsql
>> > ../liblwgeom/.libs/liblwgeom.so -L/usr/lib64 -lgeos_c -lproj -lc
>> > -Wl,-rpath
>> > -Wl,/usr/local/lib
>> > ../liblwgeom/.libs/liblwgeom.so: undefined reference to `wkt_yylex'
>> > ../liblwgeom/.libs/liblwgeom.so: undefined reference to `wkt_lexer_init'
>> > `wkt_lexer_close'
>> > collect2: ld returned 1 exit status
>> > make[1]: *** [shp2pgsql] Error 1
>> > make[1]: Leaving directory `/home/nathan/code/postgis/loader'
>> > make: *** [all] Error 1
>> > Thanks,
>> > Nathaniel H Clay
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
