[postgis-devel] [PostGIS] #1402: [raster] ST_Resample producing incorrect transformation
PostGIS trac at osgeo.org
Fri Dec 23 12:15:30 PST 2011
  Reporter:  dustymugs       |       Owner:  dustymugs
      Type:  defect          |      Status:  assigned
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by dustymugs):
 Attached test.tif is output from gdalwarp using command
 gdalwarp -t_srs "EPSG:3857" test.png test.tif
 The warped tiff has the same drift seen in PostGIS Raster.  Time to ask
 the GDAL ML about whether or not this is an issue...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1402#comment:8>
