[postgis-devel] [PostGIS] #1406: shp2pgsql crashes when loading into geography
trac at osgeo.org
Fri Dec 23 22:12:00 PST 2011
Reporter: pcreso | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
I was trying to load a GSHHS global shapefile into postgis geography using
shp2pgsql. It fails with the message below, but it succeeds when writing
geometries.
shp2pgsql -s 4326 -g geom -G -I ./GSHHS_shp/i/GSHHS_i_L1.shp coast1
*** glibc detected *** shp2pgsql: free(): invalid pointer:
0x00007fff201f52bd ***
======= Backtrace: =========
/lib64/libc.so.6(+0x74c06)[0x7f377c754c06]
shp2pgsql[0x4032fc]
/lib64/libc.so.6(__libc_start_main+0xed)[0x7f377c70123d]
shp2pgsql[0x4036b9]
======= Memory map: ========
00400000-0043b000 r-xp 00000000 08:05 15873871
/usr/bin/shp2pgsql
0063a000-0063b000 r--p 0003a000 08:05 15873871
/usr/bin/shp2pgsql
0063b000-0063c000 rw-p 0003b000 08:05 15873871
/usr/bin/shp2pgsql
0063c000-0065d000 rw-p 00000000 00:00 0
[heap]
7f377c273000-7f377c288000 r-xp 00000000 08:05 26738973
/lib64/libgcc_s.so.1
7f377c288000-7f377c487000 ---p 00015000 08:05 26738973
7f377c487000-7f377c488000 r--p 00014000 08:05 26738973
7f377c488000-7f377c489000 rw-p 00015000 08:05 26738973
7f377c489000-7f377c4df000 r-xp 00000000 08:05 26738823
/lib64/libm-2.14.1.so
7f377c4df000-7f377c6de000 ---p 00056000 08:05 26738823
7f377c6de000-7f377c6df000 r--p 00055000 08:05 26738823
7f377c6df000-7f377c6e0000 rw-p 00056000 08:05 26738823
7f377c6e0000-7f377c865000 r-xp 00000000 08:05 26738975
/lib64/libc-2.14.1.so
7f377c865000-7f377ca65000 ---p 00185000 08:05 26738975
7f377ca65000-7f377ca69000 r--p 00185000 08:05 26738975
7f377ca69000-7f377ca6a000 rw-p 00189000 08:05 26738975
7f377ca6a000-7f377ca6f000 rw-p 00000000 00:00 0
7f377ca6f000-7f377ca8f000 r-xp 00000000 08:05 26738846
/lib64/ld-2.14.1.so
7f377cc69000-7f377cc6c000 rw-p 00000000 00:00 0
7f377cc8d000-7f377cc8f000 rw-p 00000000 00:00 0
7f377cc8f000-7f377cc90000 r--p 00020000 08:05 26738846
/lib64/ld-2.14.1.so
7f377cc90000-7f377cc91000 rw-p 00021000 08:05 26738846
/lib64/ld-2.14.1.so
7f377cc91000-7f377cc92000 rw-p 00000000 00:00 0
7fff201d5000-7fff201f6000 rw-p 00000000 00:00 0
[stack]
7fff201ff000-7fff20200000 r-xp 00000000 00:00 0
[vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
[vsyscall]
Aborted
Versions used (installed from the standard OpenSUSE 12.1 AMD64 & factory
repositories (incl GEO):
psql pablo
psql (9.1.1)
Type "help" for help.
pablo=# select version();
version
PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE Linux)
4.6.2, 64-bit
(1 row)
pablo=# select postgis_full_version();
POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.8" USE_STATS
(1 row)
pablo=#
RCSID: $Id: shp2pgsql-core.h 5983 2010-09-19 11:27:05Z mcayland $ RELEASE:
1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1406>
