[postgis-devel] Uninstall machinery report
Paragon Corporation lr at pcorp.us
Sat Dec 24 10:13:18 PST 2011
> "Tough". You can't uninstall a type and leave the data in
> place, the data has no meaning without the type.
Perhaps the only thing to do if we must drop cascade a postgis type is to
ensure
there are no tables using it with a dependency check.
That's my main gripe -- I may accidentally install/run upgrade postgis in a
database that already has it or in the wrong
schema os I go to uninstall it and BAM all my data is gone.
I'm guessing that is probably what the extensions model does since it won't
let you run a
DROP EXTENSION postgis;
If you have data or non-postgis extensions associated with it unless you do
a
DROP EXTENSION postgis CASCADE;
