[postgis-devel] [PostGIS] #1404: [raster] raster2pgsql overviews don't look right
trac at osgeo.org
Sat Dec 24 10:39:10 PST 2011
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
Would you believe its the slash?
I'm retesting again to confirm, but when I used your command -- using UNIX
slash convention /*.jpg instead of \*.jpg then it worked fine and my
overviews look right.
I'm not sure this is worth fixing unless its an easy fix. If not I'll
just put a note in the docs for windows users to make sure they are using
Unix slashes.
I think for unix folks the command would completely fail anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1404#comment:9>
