[postgis-devel] pgraster: st_resample error
Tom van Tilburg tom.van.tilburg at gmail.com
Tue Dec 27 08:06:44 PST 2011
Bborie,
Sorry for checking up a bit late on the subject. Christmas was a busy time.
I'm not sure if I understand you correct about being 'geographic
correct'. Could you elaborate a bit more? I'm not very known to raster
processing.
If you wonder whether data inside the image is correct: yes it is. When
I display the image I see it as expected, but on a different position.
Cheers,
  Tom
On 24-12-2011 2:01, Bborie Park wrote:
> Tom,
> I do have a question though.  Regardless of the transformed extent,
> have you check the warped rasters to see if the data for a geographic
> point is correct?  Correct being subjective as a warped raster is
> resampled from the original raster to the new projection.
> -bborie
