[postgis-devel] [PostGIS] #1411: Remove JAR files from the repository
trac at osgeo.org
Wed Dec 28 13:34:07 PST 2011
Reporter: strk | Owner: delawen
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: Java bindings | Version: trunk
Keywords: |
The PostGIS repository should contain sources, not precompiled binaries.
There is a java/pljava/postgis_pljava.jar file instead which should likely
be removed. I don't know what is that needed for so I'd like somebody that
does to take action on this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1411>
