[postgis-devel] [PostGIS] #1017: Implement topology.ToTopoGeom(Geometry, topology_name, layer_id)
PostGIS trac at osgeo.org
Thu Dec 29 00:22:44 PST 2011
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Even more on empties: every TopoGeometry object needs to have a reference
 into a "relation" table. The table holds a list of components for each
 TopoGeometry object.
 Given we can't have a TopoGeometry id w/out at least one component, we'll
 need to add an empty component to have an empty TopoGeometry. Such empty
 component could have a special primitive with id 0. Although id 0 is taken
 for face components (the universal face), a TopoGeometry composed by face
 0 isn't documented as being legal.
 I guess void==universe==nirvana holds pretty nicely after all, doesn't it
 If we go there, we should probably make sure that TopoGeometry editors
 (add components, drop components) make sure to remove the special
 component 0 as soon as a real one is added and
 to re-add the special component 0 when all are removed.
 So far it all looks over-complex for just retaining typed emptiness during
 round-trip conversion from simple to topological feature...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1017#comment:10>
