[postgis-devel] pgraster: st_resample error
Tom van Tilburg
tom.van.tilburg at gmail.com
Thu Dec 29 00:23:12 PST 2011
Hi Bborie,
I noticed the issue has been closed in postgis.
As far as I understand the warping itself was correct, whereas the
returned metadata on the extent had an offset.
Do you say now that:
a) the extent doesn't matter, so there's no issue
b) the extent issue (if it is an issue) is fixed
if a: how do I make the extent match so it lines up properly in my GIS?
Sorry if I'm asking obvious things, it's been a long time since I did
something with rasters.
Thanks for looking into this anyway.
Tom
On 28-12-2011 16:25, Bborie Park wrote:
> Hey Tom,
> Regina asked me about a similar concern regarding tiles after they
> were projected so I did some digging yesterday. The reprojected
> tile's extent doesn't matter as long as the tile data is spatially
> correct.
> I've been double-checking the transformed rasters vs the reference
> rasters using qgis. Though the extent of the transformed tile doesn't
> match that of the source tile, the pixel data lines up correctly when
> looking for important features such as edges of the data and areas
> where I know that the data should be different (mountain ranges vs
> valleys).
> -bborie
