[postgis-devel] [PostGIS] #1413: COPY into typmod table fails on OSX
trac at osgeo.org
Thu Dec 29 12:33:08 PST 2011
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords: osx
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
Actually this was a larger problem with how the in/out functions were
handling the postgis_valid_typmod function. They were freeing an lwgeom
and then calling postgis_valid_typmod on it. So on system with looser
memory handling, the data was still there and things worked. On OSX they
didn't. I've changed postgis_valid_typmod to work on gserialized instead,
which should hopefully be a better design in any event. Committed at r8615
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1413#comment:1>
