[postgis-devel] [PostGIS] #1305: ST_Azimuth on the spheroid
trac at osgeo.org
Thu Dec 29 23:12:52 PST 2011
Reporter: realityexists | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords:
Comment(by realityexists):
Thanks for implementing this, Paul! I tried out r8577 (Windows) today and
found a couple of issues:
1) ST_Azimuth(geography) returns degrees, but ST_Azimuth(geometry) returns
radians. This should probably be consistent to reduce programmer errors
and follow the principle of least surprise.
2) When the two points are equal ST_Azimuth(geography) returns NaN, while
ST_Azimuth(geometry) return NULL. This should be consistent, too. I would
strongly recommend that both overloads return 0, because passing NULL and
NaN into ST_Project makes it return NULL and "POINT(nan nan)",
respectively. That means every programmer using ST_Azimuth and ST_Project
must be aware of this special case and code around it.
`ST_Project('POINT(10 10)'::geography, 0, 0)` returns 'POINT(10 10)' as
expected.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1305#comment:2>
