[postgis-devel] [PostGIS] #1420: ST_LocateBetween(geom, m1, m2, offset)
trac at osgeo.org
Fri Dec 30 05:17:44 PST 2011
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Description changed by pramsey:
Old description:
> Add in an LRS function using SQL/MM function naming, replaces and
> enhances SE_LocateAlong currently in SQL/MM package. Offset allows
> derived geometry to be offset to left or right of parent.
New description:
Add in an LRS function using SQL/MM function naming, replaces and enhances
SE_LocateBetween currently in SQL/MM package. Offset allows derived
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1420#comment:1>
