[postgis-devel] [PostGIS] #1404: [raster] raster2pgsql overviews don't look right
PostGIS trac at osgeo.org
Fri Dec 30 08:04:01 PST 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  reopened
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by dustymugs):
 Strange.  For the first query, I get (4, 2) where you're getting (4, 0).
 For the second query, I get the same result as you (4, 4).
 By the looks of it, I don't think this is an overview/loader issue anymore
 but rather an ST_Intersects error so maybe we should move this to a new
 ticket.  I'll have to do some thinking about this.  I'm guessing there is
 some floating-point issue when the sampling occurs around an intersection
 point.  Ideally, can you rebuild your PostGIS with --enable-debug and run
 the first query?  Having the debug output to compare with my debug output
 would be great.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1404#comment:24>
