[postgis-devel] [PostGIS] #820: ST_Within fails at walls (upright polygons)
trac at osgeo.org
Tue Feb 8 07:58:12 PST 2011
Reporter: weitzig | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: Within, ST_Within, 3D |
ST_Within doesn't find upright polygons.
Prepare example:
CREATE table walltest();
SELECT AddGeometryColumn('walltest', 'feature', -1, 'GEOMETRY', 3 );
INSERT INTO walltest(feature) VALUES ('POLYGON((1 0 5,2 0 5,2 0 10,1 0
10,1 0 5))');
Execute Example:
SELECT feature FROM walltest WHERE ST_Within(feature,'POLYGON((-5.0 -5.0
0.0,5.0 -5.0 0.0,5.0 5.0 0.0,-5.1 5.0 0.0,-5.0 -5.0 0.0))')='T'
The query should find the polygon, but it doesn't.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/820>
