[postgis-devel] [PostGIS] #135: Upgrade geocoder to use the new tiger 2010 files
trac at osgeo.org
Wed Feb 9 20:57:45 PST 2011
Reporter: robe | Owner: sfrost
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords: tiger
Changes (by robe):
* status: new => closed
* resolution: accepted => fixed
Comment:
We've ammended the tiger geocoder to work with tiger 2010 and as far as we
can tell, it works fine. At least for Massachusetts data anyway. We'll
be stress testing it more with a consulting project we are currently
working on and tweaking it as we go along, but we consider it more or less
done. It is now also documented as part of the official PostGIS docs.
http://www.postgis.org/documentation/manual-svn/Extras.html#Tiger_Geocoder
We still haven't gotten around to testing the loader script on linux if
anyone else wants to take a stab at that. Jan had tested it on Ubuntu for
our book, and we incorporated his corrections as best we could.
We may add a reverse geocoder function to it before we are done since
we'll need to build that anyway for work we are currently doing, but will
add that as a separate task item.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/135#comment:10>
