[postgis-devel] [PostGIS] #791: Topology: function GetEdgeByPoint($1, $2, $3)
trac at osgeo.org
Mon Feb 14 03:08:50 PST 2011
#791: Topology: function GetEdgeByPoint($1,$2,$3)
Reporter: aperi2007 | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by nicklas):
Hallo
I don't know the ST_Intersects algorithm but the problem for ST_Dwithin is
that the faster way of doing it in 1.5 will not be used in the cases where
the bounding-boxes intersect. In the case of using ST_DWithin as a
intersection test the faster algorithm will never get used because the
cases with no intersecting bounding boxes will be sorted away already by
the index.
So, until Paul implements his indexing of vertexes in
distance/intersection presented
here [http://postgis.refractions.net/pipermail/postgis-
devel/2009-December/007710.html]
and here
[http://blog.cleverelephant.ca/2009/11/is-good-enough-good-enough.html]
until then, I am afraid we will have to live with the brute force way of
doing the calculation for ST_DWithin(geoemtry, 0)
But what I enhanced in 1.5 was also that I put in a lot of more "Is the
answer already given" tests, which might give quite a lot better
performance in those cases. Before 1.5 this was only tested once per
interior ring.
strk, do you have insight in ST_Intersects algorithm?
Regards
Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/791#comment:9>
