[postgis-devel] [PostGIS] #310: port ST_DumpPoints() to C
trac at osgeo.org
Tue Feb 15 14:01:17 PST 2011
Reporter: kneufeld | Owner: pramsey
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS Future
Component: postgis | Version: trunk
Keywords: |
Changes (by bitner):
* cc: bitner (added)
Comment:
Hacky test that shows potential performance gain by getting away from the
plpgsql looping structure with npoints. Dumping a 2600 point linestring
takes almost a second with st_dumppoints and ~30ms with this function.
CREATE OR REPLACE FUNCTION dump_linestring_points(geometry)
RETURNS SETOF geometry AS
$BODY$
SELECT
'SRID=' ||
bar ||
';POINT(' ||
foo ||
)::geometry
FROM
regexp_split_to_table(
rtrim(
substring(asewkt($1) from 23)
) as foo , srid($1) as bar
WHERE st_geometrytype($1)='ST_LineString';
$BODY$
LANGUAGE sql IMMUTABLE STRICT
COST 1
ROWS 100;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/310#comment:1>
