[postgis-devel] [PostGIS] #497: [raster] Start testing displaying PostGIS raster with Mapserver
trac at osgeo.org
Wed Feb 16 05:57:15 PST 2011
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
Jorge,
I'm still not quite understanding . I'm still not quite clear why you
need to pull the whole tables metadata (even with a distinct on those
elements -- which is pretty slow too). Wouldn't it be sufficient to pull
the records that overlap the region of interest or even do a limit 1 call
for the meta data? Or is the issue because you need to start a a pixel
(0,0) and need to know its offset from that?
If I use mode='2' I was assuming that meant to create one GDALRaster
dataset and assume that by saying mode='2' I'm basically saying its evenly
blocked, it has the same srid and there are no overlapping tiles.
otherwise I'd want multiple datasets.
If that is not the case then like I said we should introduce a mode='3'
since I really think this is the most common use case.
That said I would think you could reduce your first call to
SELECT (foo.md).srid, (foo.md).skew , etc.
FROM (select st_metadata(rast) as md from aerials.o_2_boston WHERE rast
somebbox
LIMIT 1) as foo }}}
or at the very list put in a rast && somebbox call in there.
In the second query you do a spatial range anyway so I would expect the
metadata call to do the same is all. I'll play around with not tiling and
see if it is better.
I think part of the issue of the slowness in this particular usecase I am
testing is that when using OpenLayers I normally use the buffer tiles mode
so the responsiveness is better (e.g. if you have a 600x600 screen -- it
will break it into several calls so you can see the screen loading -- so I
might have like 12 calls of 100x100 pixelsize each. So the fact you are
pulling the meta data of the whole table on each call is really killing
the performance.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/497#comment:12>
