[postgis-devel] [PostGIS] #588: [raster] Implement the one raster version of ST_MapAlgebra
trac at osgeo.org
Thu Feb 17 04:43:51 PST 2011
Reporter: pracine | Owner: jorgearevalo
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
That's the weird thing - everything was going good and then suddenly I
would get errors like SELECT CASE WHEN mod(200.00,2) ... rast (RAST does
not exist) errors.
Though I can't trip it up now with a case: These work fine for example,
but it wasn't the one I was testing yesterday (which is why I thought it
was one of those heisenburgs).
However I do keep on getting a notice that my initial value is truncated
when I do things like this:
ALTER TABLE dummy_rast ADD COLUMN map_rast raster;
UPDATE dummy_rast
SET map_rast = st_mapalgebra(rast, 'CASE WHEN mod(rast,2) = 1 THEN rast
WHEN rast = 254 THEN 100 WHEN rast < 253 THEN mod(rast,4) ELSE rast END')
WHERE rid = 2;
Is that one of those weird windows bugs?
Gives warning:
WARNING: Initial pixel value for 8BUI band got truncated from -128.000000
to 128
But result above looks right.
I think the other case with the PixelType not working was user error on my
part. I had typed 2BB instead of 1BB or 2BUI. I didn't get a warning
message or error, but it didn't convert the pixeltype -- it left it as
8BUI. I think maybe we should throw an error if someone types in an
invalid PixelType -- you know just for people like me :). It wouldn't be
pleasant if you thought that you had a 2BB pixel band and 1 million
updates later, you realized it was really 8 BUI.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/588#comment:7>
