[postgis-devel] [PostGIS] #837: ST_MapAlgebra -- I think we have a memory leak
trac at osgeo.org
Thu Feb 17 06:47:57 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Changes (by robe):
* version: 1.5.X => trunk
Old description:
> I tried to do this on my test elephant
> UPDATE ch13.pele SET map_rast = ST_MapAlgebra(rast,'CASE WHEN rast
> BETWEEN 100 and 250 THEN 1 WHEN rast = 252 THEN 2 WHEN rast BETWEEN 253
> and 254 THEN 3 ELSE 0 END', '2BUI') WHERE rid = 2;
> and it crashes the server after about 13 seconds.
> This is on Windows XP latest trunk.
New description:
-- its a single tile -- I forget the size
UPDATE ch13.pele SET map_rast = ST_MapAlgebra(rast,'CASE WHEN rast BETWEEN
100 and 250 THEN 1 WHEN rast = 252 THEN 2 WHEN rast BETWEEN 253 and 254
THEN 3 ELSE 0 END', '2BUI') ;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/837#comment:1>
