[postgis-devel] [PostGIS] #845: ST_Intersects() precision error - returns false instead of true
trac at osgeo.org
Thu Feb 24 01:10:34 PST 2011
Reporter: cdestigter | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by strk):
Not a precision issue, or ST_Relate and ST_Disjoint would also be wrong.
Sounds more like a conceptual bug like a shortcut or something.
Quick, easy test:
select (a && b) as "&&", st_relate(a, b), st_intersects(a, b),
_st_intersects(a,b), st_disjoint(a,b) from
(select
'POINT(169.69960846592 -46.5061209281002)'::geometry
as a,
'POLYGON((169.699607857174 -46.5061218662,169.699607857174
-46.5061195965597,169.699608806526 -46.5061195965597,169.699608806526
-46.5061218662,169.699607857174 -46.5061218662))'::geometry
as b) as foo;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/845#comment:1>
