[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
trac at osgeo.org
Mon Jan 3 01:27:02 PST 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Mark,
I tried with a table using my December 30th build I had posted which is
the one Andrea is using, and I get the same problem with any table.
It stuffs in an extra ..
when I run this:
shp2pgsql -s 4269 -d -g geom -D -i -I -W "UTF-8" place public.place >
places.sql
The output of my file looks like:
SELECT DropGeometryColumn('public.','place','geom');
DROP TABLE "public."."place";
I tried with different schemas and quoting the schema and it does the same
thing - its not parsing the schema name out right.
Mark -- I presume its more than just a MingW problem since Andrea says it
happens on his Debian install as well. I don't think its getopt either.
I think maybe the period check or something is wrong in shp2pgsql-cli.c
(somewhere around line 185-190) and maybe its specific to 32/64 bit maybe?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:6>
