[postgis-devel] [raster] Tweaking overviews in raster2pgsql.py
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Jan 4 14:27:33 PST 2011
+1
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Mateusz Loskot
>Sent: 2 décembre 2010 13:06
>To: postgis-devel at postgis.refractions.net
>Subject: [postgis-devel] [raster] Tweaking overviews in raster2pgsql.py
>Hi,
>I'd like to propose a small simplification to the overviews management
>in the raster loader script. Currently, raster2pgsql.py takes explicit
>overview factor (called level, incorrectly in my opinion).
>This follows gdaladdo appraoch where it accepts list of overview
>reduction factors used to generate overview levels.
>I'd like to get rid of this explicit factors and simplify things a bit,
>I'd like to follow the techniques users already know from slippy maps,
>Google Maps, Oracle etc.
>The command would change from
>raster2pgsql.py -t mydata ... (base level)
>raster2pgsql.py -t mydata -l 2 ...
>raster2pgsql.py -t mydata -l 4 ...
>raster2pgsql.py -t mydata -l 8 ...
>The command would change to simple:
>where the N=8 means that user requests 8 overview levels in total,
>including base raster.
>The levels are numbered as follows: 0, 1, 2, ..., N-1
>The overview reduction factor is calculated based on level number:
>2 ^ Ni
>where Ni is the actual level number:
>level=0 => overview factor=1 (base raster)
>level=1 => overview factor=2 (reduction by 2)
>level=2 => overview factor=4 (reduction by 4)
>... etc.
>This would generate overview tables named after overview level
>but not overview factor. The latter is already stored in metadata.
>mydata (base raster)
>mydata_o_1 (overview factor=2)
>mydata_o_2 (overview factor=4)
>mydata_o_3 (overview factor=8)
>This calculation is reversible making it possible to calculate overview
>level from given reduction factor:
>level = log(overview_factor) / log(2)
>factor = pow(2, level)
>The simplification is that there is only *one* variable information
>carried around, it is total number of overview levels.
>All the rest values are easily calculated based on that.
>What you say?
>Best regards,
>Mateusz Loskot, http://mateusz.loskot.net
>Charter Member of OSGeo, http://osgeo.org
>Member of ACCU, http://accu.org
>_______________________________________________
>postgis-devel mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
