[postgis-devel] Calling Index Genii
Nicklas Avén nicklas.aven at jordogskog.no
Wed Jan 5 08:02:30 PST 2011
great
.. or not so great, would have been more way that way I guess ...
2011-01-05 skrev Paul Ramsey :
Yes, sure. And now that I've counted the tree traversal that makes me
>even more sure.
>P
>On Wed, Jan 5, 2011 at 7:33 AM, Nicklas Avén wrote:
>> Hi Paul
>> Sorry for repeating myself, but are you sure you don't have a 3d index after
>> all, even if you input 2d geometries. From some
>> "add-empty-z-value-mechanism"?
>> just curious
>> /Nicklas
>> And I just did turn on logging and hey presto, both indexes take about
>>>the same number of tree traversals to generate the result. So the
>>>trees are more-or-less the same shape. So... what's left? I'll post
>>>the shark results to see if anything jumps out at you Mark, doesn't
>>>jump out at me. At this point the only thing I've got left is using a
>>>varlena key in the new index and a fixed length one in the old one.
>>>P.
>>>On Fri, Dec 31, 2010 at 3:15 PM, Paul Ramsey wrote:
>>>> Actually first I need to just turn on logging and count the number of
>>>> calls to gist consistent. If my guess about the bad tree is right, I should
>>>> see about five times as many calls on the new index. If the number of calls
>>>> is in the same order of magnitude, suspicion shifts to the varlena key and
>>>> associated overhead (which I find hard to believe).
>>>> I have already run it through the shark and it is not very useful... At
>>>> least the functions it points to don't scream, hey! Look at my huge
>>>> overhead!
>>>> P.
>>>> On 2010-12-31, at 4:11 AM, Mark Cave-Ayland wrote:
>>>>> On 31/12/10 06:15, Paul Ramsey wrote:
>>>>>> Actually, testing again on the laptop (apples to apples) the speed
>>>>>> different with 2D data is down to 3ms-on-new vs 1ms-on-old. When
>>>>>> pulling a much larger result set (2000 records) the speed difference
>>>>>> is 10ms-on-new vs 6ms-on-old. So it's closer, but still not
>>>>>> equivalent.
>>>>>> P.
>>>>> Sounds like it's time to build a profileable version of the library. Can
>>>>> you build with CFLAGS="-O0 -pg" and then use your favourite profiling tool
>>>>> (gprof/Shark) to see the differences in where the time is being spent?
>>>>> ATB,
>>>>> Mark.
>>>>> Mark Cave-Ayland - Senior Technical Architect
>>>>> PostgreSQL - PostGIS
>>>>> Sirius Corporation plc - control through freedom
>>>>> http://www.siriusit.co.uk
>>>>> t: +44 870 608 0063
>>>>> Sirius Labs: http://www.siriusit.co.uk/labs
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110105/59d275f9/attachment.html>
