[postgis-devel] [PostGIS] #737: wmsservers get rid of deprecated calls
trac at osgeo.org
Fri Jan 7 02:36:50 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
make check stops in the first directory where tests are not successful, so
keeping wmsservers_old around and running prevents other tests from being
run.
If it's expected to fail, please let's drop it, or have regress/run_test
include the legacy stuff (or a mix of the two, if you have time to be very
nice, like having a set of legacy tests which are run in their own dir
with an additional --legacy switch to run_test, like I did for
--topology)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/737#comment:2>
