[postgis-devel] [PostGIS] #758: [raster]: Using deprecated join select functions postgis_gist_sel postgis_gist_joinsel
PostGIS trac at osgeo.org
Fri Jan 7 22:29:03 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Jorge,
 I'm really not sure whether you even need the gserialized check you have
 in place:  If you do, then I think the code should be:
 #ifdef GSERIALIZED_ON
 CREATE OPERATOR && (
     LEFTARG = raster, RIGHTARG = raster, PROCEDURE = st_overlap,
     COMMUTATOR = '&&',
     RESTRICT = geometry_gist_sel, JOIN = geometry_gist_joinsel
 #else
     COMMUTATOR = '&&',
     RESTRICT = contsel, JOIN = contjoinsel
 #endif
 Like I mentioned on dev: http://www.postgis.org/pipermail/postgis-
 devel/2011-January/011309.html
 Both the gserialized and regular seem to work just fine with
 geometry_gist_sel, geometry_gist_joinsel  - so I'm not clear if you even
 need this def check at all.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/758#comment:1>
