[postgis-devel] [PostGIS] #760: Topology fail some checks
    trac at osgeo.org
    Sun Jan  9 13:47:24 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Strk,
 These failures are all because I removed the deprecated functions
 intersects, x,y,z,issimple etc.
 I was meaning to make check on topology, but I can't.  It seems as far as
 I can tell, its not inheriting my path settings.  Says psql does not exist
 etc.  I have similar issue with raster since the configure change you made
 a month or so ago.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/760#comment:2>
