[postgis-devel] [PostGIS] #762: Raster some check fails
trac at osgeo.org
Mon Jan 10 10:24:20 PST 2011
Reporter: aperi2007 | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
just executing "make raster-post-install-check" I see these errors:
./run_test check_raster_columns.sql check_raster_overviews.sql rt_io.sql
create_rt_bytea_test.sql rt_bytea.sql create_rt_box2d_test.sql
rt_box2d.sql rt_addband.sql create_rt_properties_test.sql
rt_dimensions.sql rt_scale.sql rt_upperleft.sql rt_rotation.sql
rt_georeference.sql rt_set_properties.sql create_rt_empty_raster_test.sql
rt_isempty.sql rt_hasnoband.sql create_rt_band_properties_test.sql
rt_band_properties.sql rt_set_band_properties.sql rt_pixelvalue.sql
create_rt_utility_test.sql rt_utility.sql create_rt_gist_test.sql
rt_above.sql rt_below.sql rt_contained.sql rt_contain.sql rt_left.sql
rt_overabove.sql rt_overbelow.sql rt_overlap.sql rt_overleft.sql
rt_overright.sql rt_right.sql rt_same.sql rt_spatial_relationship.sql
bug_test_car5.sql
Creating spatial db rtpostgis_reg
createlang: linguaggio "plpgsql" già installato nel database
"rtpostgis_reg"
TMPDIR is /tmp/rtpgis_reg_11269
PostgreSQL 9.0.2 on i686-pc-linux-gnu, compiled by GCC gcc (Debian
4.3.2-1.1) 4.3.2, 32-bit
Postgis 2.0.0SVN - 2011-01-10 18:26:09
GEOS: 3.3.0-CAPI-1.7.0
PROJ: Rel. 4.7.1, 23 September 2009
WKTRaster 2.0.0SVN - 2011-01-10 18:26:09
Running tests
check_raster_columns. ok
check_raster_overviews. ok
rt_io. ok
create_rt_bytea_test. ok
rt_bytea. ok
create_rt_box2d_test. ok
rt_box2d. ok
rt_addband. failed (diff expected obtained:
/tmp/rtpgis_reg_11269/test_8_diff)
create_rt_properties_test. ok
rt_dimensions. ok
rt_scale. ok
rt_upperleft. ok
rt_rotation. ok
rt_georeference. ok
rt_set_properties. ok
create_rt_empty_raster_test. ok
rt_isempty. ok
rt_hasnoband. ok
create_rt_band_properties_test. ok
rt_band_properties. failed (diff expected obtained:
/tmp/rtpgis_reg_11269/test_20_diff)
rt_set_band_properties. ok
rt_pixelvalue. ok
create_rt_utility_test. ok
rt_utility. ok
create_rt_gist_test. failed (diff expected obtained:
/tmp/rtpgis_reg_11269/test_25_diff)
rt_above. ok
rt_below. ok
rt_contained. ok
rt_contain. ok
rt_left. ok
rt_overabove. ok
rt_overbelow. ok
rt_overlap. ok
rt_overleft. ok
rt_overright. ok
rt_right. ok
rt_same. ok
rt_spatial_relationship. ok
bug_test_car5. ok
Run tests: 39
Failed: 3
make[3]: Leaving directory
`/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test/regress'
make[2]: Leaving directory
`/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test'
make[1]: Leaving directory
`/home/postgres/software/postgis/postgis-2.0.0SVN/raster'
postgres at deb:~/software/postgis/postgis-2.0.0SVN$
I add the tmp logs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/762>
