[postgis-devel] [PostGIS] #765: Topology: error adding two edge with a common node
trac at osgeo.org
Tue Jan 11 07:11:41 PST 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: wontfix | Keywords:
Changes (by aperi2007):
* status: new => closed
* resolution: => wontfix
Comment:
I try even this other code:
DROP TABLE IF EXISTS CARICAMENTO.TEST;
CREATE TABLE CARICAMENTO.TEST(ID INTEGER PRIMARY KEY, CODICE TEXT);
SELECT topology.DropTopology('schema_topo');
SELECT topology.CreateTopology('schema_topo',3003, 0.00005);
SELECT topology.AddTopoGeometryColumn('schema_topo', 'caricamento',
'test', 'topo_line', 'LINE');
-- insert all edges
select topology.ST_AddIsoEdge(
'schema_topo',
topology.ST_AddIsoNode('schema_topo',NULL,ST_GeomFromEWKT('SRID=3003;POINT(1
4)')),
topology.ST_AddIsoNode('schema_topo',NULL,ST_GeomFromEWKT('SRID=3003;POINT(2
2)')),
ST_GeomFromEWKT('SRID=3003;LINESTRING(1 4, 2 2)')
'schema_topo',
2, -- (2 is the code for the common node)
topology.ST_AddIsoNode('schema_topo',NULL,ST_GeomFromEWKT('SRID=3003;POINT(4
4)')),
ST_GeomFromEWKT('SRID=3003;LINESTRING(2 2, 4 4)')
But in this case I have again another error:
ERROR: SQL/MM Spatial exception - not isolated node
So the ST_AddIsoEdge seem usable only to add isolated-edge.
So I understand that ST_AddIsoEdge the prefix ISO is for Isolated don't
for I.S.O.
this is not a bug !
close the ticket.
sorry for noise.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/765#comment:1>
