[postgis-devel] [PostGIS] #768: Probe_geometry_columns() don't work correctly
trac at osgeo.org
Tue Jan 11 13:52:03 PST 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
the probe_geometry_column seem don't work correctly.
I try this code sql:
drop table if exists caricamento._csr_map_crop_multiline;
-- _csr_map_crop is a multipolygon table
create table caricamento._csr_map_crop_multiline as select
a.gid,a.idmappa,ST_Boundary(a.geom) from caricamento._csr_map_crop as a
where ST_IsValid(a.geom)=true;
SELECT Probe_Geometry_Columns();
the result seem ok because no error is given.
But opening the geometry_columns table there isn't the
"_csr_map_crop_multiline" table.
I try this on a debain 32bit with postgis 200 trunk and with postgres
9.0.2
More information:
executing the sql I have reported a good number of self-intersection.
But I don't think that self-intersection are relate to this problem.
W (183): Self-intersection at or near point 1.70284e+06 4.84765e+06
W (184): Self-intersection at or near point 1.70402e+06 4.85107e+06
W (185): Self-intersection at or near point 1.68837e+06 4.85484e+06
W (186): IllegalArgumentException: Invalid number of points in
LinearRing found 3 - must be 0 or >= 4
W (187): Self-intersection at or near point 1.69997e+06 4.8436e+06
W (188): Self-intersection at or near point 1.67601e+06 4.85714e+06
W (189): Self-intersection at or near point 1.67035e+06 4.87667e+06
W (190): Self-intersection at or near point 1.67163e+06 4.87903e+06
... W (260): Self-intersection at or near point 1.62796e+06 4.84335e+06
W (261): Self-intersection at or near point 1.69071e+06 4.84526e+06
W (262): IllegalArgumentException: Invalid number of points in
W (263): IllegalArgumentException: Invalid number of points in
W (264): Self-intersection at or near point 1.70798e+06 4.85299e+06
W (265): Self-intersection at or near point 1.59653e+06 4.87314e+06
W (266): Self-intersection at or near point 1.63454e+06 4.87679e+06
W (267): Self-intersection at or near point 1.68673e+06 4.84699e+06
W (268): Self-intersection at or near point 1.69834e+06 4.89465e+06
Regards.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/768>
